Widescreen Monitor with foldable stand?
Caporegime
18 Oct 2002
Lake District
I require a monitor that I can rotate into portrait orientation and maybe even fold flat or on a slight rake (incline) from front to back.
Does anything like this exist that doesn't cost the earth?
Probably looking for 24 inches or there abouts.
Thanks.
I've seen monitors which are basically just the screen without the stand (they come with something to prop them up), you can lay them flat if you want.
I'll see if I can find it.
edit HP x2401 is the model, as you see it can be laid flat and has ports at the side :) hope that helps.
