Widgetlocker how to set it up?
7 Jan 2007
Sussex, UK
Bought Widget locker and it is better than default unlocker, but how can I customise it?
How can I add in new programs to the swipe menu locker thingy?
When you launch the app its setup like your home screen. I.e. press/hold in empty space, then add shortcuts, widgets, swipe locker etc. Then drag and drop around the screen, most android apps also rely on the 'hard' menu button.
Yeah, every things customisable. All I'm saying is when you go into your app draw and select widget locker, you get taken to the locker homescreen in tool/edit mode. Eg, long press on the clock to move it around or delete. Press the menu button to add custom slider or select settings (e.g. look & feel > slider layout > iPhone ;))
I'd also recommend downloading TeslaLED from the market (free from the same developer)
It's turns your camera flash into a touch (on/off widget on your home screen or stick it on a locker slider etc)
Oh and don't forget to turn off the default lock screen (main settings > location & security >screen lock off)
ok sorted. On an unrelated issue. I have rooted the phone, installed overclock milestone app but can only selected 74v with 1000mhz, is this ok?
