Widgets - How to manage?
Permabanned
9 Oct 2007
Hi guys
How do you manage widges, e.g. I got istat 4.5
But I do not know how to have it constantly on the bottom bar for ease, as like Safari, system prefs etc is.
How do I even get to them now?....Theres nothing on the bottom bar, is it possible to put Istat on the bottom bar thing?
NOOOB! - Sorry about this.
I'm guessing you mean the dock - no.
widgets live on the dashboard, which you can access by hitting (iirc) F12. You can also change your Expose preferences to put a hot corner for dashboard access, too - mine's set to bottom left, although you didn't need to know that :/
you can also click the dashboard icon in the dock to bring it up
you can get widgets onto the desktop, but that's not where they're supposed to go, and I think they just get in the way
