- 6 Sep 2005
Ok, bear with me, this is going to take some explaining.
At my office i have a Datacard SP75 card printer, used for printing ID cards for our customers. I have recently redesigned our company ID card to take advantage of the high quality print. I made a new template image in Illustrator, and exported the file to a PNG file. i then took the photo of the person the card is for, and erased the background and saved it as a PNG so that our markings would go behind their head. (See example)
The problem i am having is that every time i try to print this card, the photo is missing. If i change the photo to another format (jpg, bmp) then it prints fine, but the background is white not transparent. I also tried changing the format of the template to jpg and leaving the photo as png but it still doesn't print the photo.
I contacted Datacard a while ago, and they seemed completely stumped by it. Does anyone know what could be causing this wierd problem. It only seems to be a problem when i try to print a PNG file with transparency on it.
Any help would be greatly appriciated.
Gopher
Gopher
