Wierd Prob with 3870
17 Apr 2004
S.Wales
Just bought a 3870 ATI sapphire, and samsung 223bw monitor plugged through dvi, currently running vista 64, latestest cat drivers (tried 8.3/8.4) and reference samsung driver with windows and it wont let me go above 1024x768 res, really wierd, dunno what else to try??
re-format?
i had a similar problem with my crt i changed the res and the screen went black(out of snyc msg)
i solved this by turning of pc and swapping the monitor to the 2nd monitor slot on the gfx card.
when i booted back up windows detected my monitor and i could use a higher res.
maybe worth a try rather than reformatting.
hope this helps
