- 9 May 2005
Had the battery pack for 3 months and its just starting acting wierd today, the lights on the controller were flashing so I hooked up my play and charge cable, no charging light come on.
I checked in the guide to see if the guage was moving and there wasnt one
So I tried charging up my other pad and battery and that works fine, I even changing the pad/packs around to eliminate the pad or cable as the problem.
My initial though was it must be borked but if you start the machine up with a pad containing the battery in question it works fine and the guage is there, but connect the charge cable up and you get no light plus no guage. Wierd or what?
