wierd USB key problem
29 Jul 2004
Esher
i bought a Sony 8GB memory stick from the bay.
basically the problem with it is that when i plug the usb key in, my computer then freezes, it eventually unfreezes and when i try to select the key on my computer it takes ages to select it, and the same sort of thing happens when i try to select, delete or open files on the usb stick.
that i can actually live with but its this which i cant, i transferd a notepad file on there, which contained 16 characters, when i plugged it into my laptop all the characters in the word document turnd into 0's. i then transferred 3albums onto it, all of which were contained in 1 folder. when i plugged it into my lapop it changed each file into a folder and each folder name into 0's.
i tried deleting it but the computer says that the data is corrupted and unreadable.
has this ever happened to anyone else?
Phnom_Penh said:
Have you formatted the drive (and maybe partitioned etc) to check it's actually an 8gb one?
stupid question but how do i format it?
when you select the device on my computer the info on the left side panel says its an 8gb one
