WiFi AC Bluetooth combo card?
12 Apr 2007
Hi all
I have a need for a Bluetooth 4.0 adapter for xbox pad.
I could also do to upgrade my wireless n USB dongle to a wireless AC pci or m.2 card.
Ive seen you can get combo cards that have both and this seems neater and more cost effective than buying 2 seperate cards /dongles.
Anyone have experience of these?
Thanks
As long as you buy the right card for the available slot along with OS driver support being available, then it s plug and play, give a bit of thought to the antennae connection and placing.
I have an old intel 8260NGW in my ASUS C4H, it’s a 2.4/5Ghz Wi-fi and BT 4.2 card, it’s not cutting edge in either AC speeds or BT, but it works and they’re cheap. Check OS support before you buy though.
