WiFi / Bluetooth card
5 Oct 2023
Manchester uk
Hi there,
Can anyone recommend a reliable no fuss with drivers WiFi / Bluetooth card to go with B650M PG riptide mobo please?
Need speed for gaming streaming etc
Thanks
Hi there,
Thanks
Use a LAN cable if you want the best performance.
If you can’t use a cable, any good wifi 6e Intel adapter with preferably a 3X3 antenna setup.
Most are 2X2 though (AX211,411,etc)
I have used all of these: Gigabyte WBAX200, GC-WB1733D-I, Asus PCE-AC55BT. No drops or other issues with BT and Sky hubs and haven't needed to install a driver. Rarely bother looking at the speed.
