Wifi camera with stun gun
31 Dec 2005
Always on the M1.....
Have 2 cats, one of which is pee'ing on my sofa. I'm after a network +/- wifi camera which will ping pictures if activated.
If it came with a stun gun, that'd be even better!
Any one any thoughts? (Maybe even along the lines of put in network forum..)
I think what you actually want is a laser trigger remote. Not sure if that's what it is called, but you can set up lasers that remote triggers a camera.
Wildlife togs use it with a bird feeder I believe!
kd
Or rather than torture animals you could put orange peel around the area they go, as they don't like the smell.
Need to know which cat to fall out with... They both look like butter wouldn't melt but obviously one of them is doing it.
Tried orange peel, they promptly cr**ped all over the sofa, as if to say point out how little they are affected by orange peel.
Liking the idea of a laser trigger though, rapid burst wouldn't half scare the living daylights out of them, might even be a deterrent itself! Assume they're not cheap though?
And 42zx - if I had my way, would be a dog every day of the week!
PS I'll try most things once, but draw the line at animal fetishes, thank you!
Just ordered this TriggerTrap. No idea if it's particularly good but for 30 coins and that blasted Prime delivery thing I forgot to cancel, I'll give it a go.
Wonder if facial recognition works on cats??
How about some kind of automated Phalanx system? You wouldn't need to worry about the weeing then although the blood may be a little difficult to clean out of the sofa, if there was any sofa room left.
You sure it's your cat?
I had the same problem, turned out to be a neighbours cat coming in and marking it's territory.
It hasn't come back...... ;)
Just get one of those motion sensor air freshners, put it on the sofa and a blast of "fragrant spring flowers" up the jacksy will give 'em a shock! Of course they could then just attack it, and a remote camera will still be needed to capture all of this...
