Hi guys,
I need two recommendations.
One is for a pci-e wifi card.
And the other is for a non pci-e wifi card in case all my slots are taken post build. What non pci-e options are there that aren't throttled by the max speed of the interface? My internet speed is around 65mbits (fibre).
My only requirement for both is that it must support the latest spec (802.11ac afaik?) and maximum bandwidth. And of course it must support Windows 10 with good driver support.
Thanks.
Edit: A powerline device (hopefully gigabit) will do as well if you prefer to recommend one of those?
Thanks.
