- 28 Oct 2003
- Worthington-on-sea
I'm having a problem at the moment with the stability of my internet connection. It's mostly noticable when I'm on a P2P network or online gaming.
Take Counter Strike for example. After about 10 minutes of play my connection seems to time out and I'm left hanging before getting kicked by the server. When I check the ping rates to the servers they all come back as 'no response' for a minute or so before coming back.
I run a secured wireless network from my NTHell STB through a Belkin router. There are another two wireless networks that I can detect and all three are running on channel 11. Would changing my channel help with this problem do you think? If so, which should I change to (11 is default it seems).
Also, are there any good programs for testing the stability of my net connection?
Thanks in advance.
Thanks in advance.
