Hi,
I'm looking for a good Wifi Extender/Repeater to extend a friend's existing wireless-G from an old D-Link router to an outbuilding 20-30 metres away. The house where the router is has that new insulation with silver foil in the walls and so does the outbuilding. I think that is affecting the signal partly at least.
I've tried to extend the range with a cheap TL-Link wireless-G £20 extender which did extend it to just outside the outbuilding, but as soon as you are inside it's gone. That was with the extender on the window sill in the house closest to the outbuilding too.
So would something like this:
http://www.overclockers.co.uk/showproduct.php?prodid=NW-030-TP
do the job?
Any suggestions?
Was also thinking I could replace the antenna's but these routers and repeaters etc never say what DBi the existing antenna's are so not sure if it would make any difference. I saw a few cheap 9 DBi antenna's which I hope would help, difficult to say if they would though!
Anyway, any help/comments appreciated.
Thanks
do the job?
Any suggestions?
Thanks
