Wifi Homeplugs
16 Apr 2007
UK
Hey all,
So I've got some homeplugs that are working great at the moment, and some of you may recall a thread I created about network switches where I was thinking of getting a switch to split the ethernet connection to my macbook to my xbox 360 as well across the other side of the room.
However, I just thought - If I got a homeplug that could provide wifi in my room as well as a physical ethernet connection, it would be perfect.
Firstly, do these exist? And secondly, any recommendation if there are?
Remember, I need a homeplug that dishes out wifi, as well as one physical ethernet port.
Thanks,
Marky
Just seemes easier to use a switch with a wireless ap rather than having to replace the already purchased homeplugs. I reckon if you would buy second hand you could pick a simple one up for less than a tenner.
