I have a wireless g network in my house, and I have been plagued with wireless disconnections since I installed it. Its a WRT5G4g linskys cable router and a belkin pci wireless card in my pc.
Basically at seemingly random times (ranging between minutes to hours) the wireless connection will drop and turn to LAN only or will totally disconnect. The only way I have worked out to reconnect is to disable/enable the wifi card in device manager. I have been doing this about 5 times a day for ages, but its stopping me playing games online as the connection wont last the length of a match.
I should note this only happens on my computer and there are two other laptops in house that arent having any problems.
I tried switching OS (vista, xp and 7) and its the same on each. Changed wifi card drivers, moved my computer to different places in the house. I also bought a different pci card and it was exactly the same.
I have monitored the channels of other networks in range, and theres no conflict there and Im usally getting 4/5 bar connection strength in vista. Also the problem persits unsecured and with WPA2.
Does anyone have any ideas what to try next? I was thinking maybe N band router, 5ghz network (2,4ghz telephone in the house) or USB dongle. But I dont want to be wasting money on things that arent going to help. I think the obvious step is wired but I need to avoid if possible drilling holes around the house! Its not exactly a challenging setup I am like 3m above the router.
