Wifi mouse weird?
23 Dec 2002
Shiny Shanghai
Hi there
My old wifi mouse died, so I picked up a new one.
And it's weird to describe, but the normal "wave your hand left to right" motion you do when using a mouse and wanting to go from east to west on your screen (or indeed 9oclock to 3oclock) is off.
It's taking me from 8oclock to 2oclock.
I plugged in a cheap and cheerful wired mouse I had laying around and the usual hand motion works perfectly.
9oclock to 3oclock
I then tried another wifi mouse and it had the same offset.
Ever since my old wifi mouse died, all new ones I'm trying are offset.
Literally no idea how to troubleshoot or fix this.
Any advice? :(
More investigation tells me this is a Windows issue and not a mouse issue :(
Will start thread in the Windows section.
