WiFi over lan?
10 Jan 2009
Hi, I'm considering asking my neighbour if I could share his internet connection.
Is there any way in which I could pick up his WiFi signal, and feed it into my LAN with a router or something? I would rather have a piece of hardware do the sharing instead of having to leave a machine on for it to share the connection?
cheers
Will have a look when I finish work cheers mate :)
is it fairly straight forward to get going or hard work?
Assuming the router supports (or you can install firmware that supports) wireless bridging, then it's as simple as connecting any wireless client.
SSID and key are all that should be needed.
