Wifi Printer
18 Oct 2002
Hi All
I am wondering is there any Wifi Printer out there on the market, NOT bluetooth but Wifi that can work from a Wifi enable laptop.
OR
Is there a adaptor that can be got to put onto the printer?
Regards
Yes there are a few wifi printers out there but they are expensive usually, you can buy an HP all in one fax, scanner, copier, printer for about £400 with wireless. There are probably cheaper ones but that was one that I saw.
OR you can get a USB wifi print server for around £50-60. I suggest getting a print server because then you are not limited to a printer that has built in Wifi.
