Wifi Question
17 Aug 2010
Hi,
So im going to university in a few weeks, in my room there is an Ethernet port, I am looking into a device that will allow that Ethernet port to become a secure WiFi network am I just looking for an extender?
Many thanks!
Any wireless router will work. Ethernet cable from wall to router, set up wireless how you want it. You should also be able to plug into the spare ethernet ports if you want to.
Just a word of caution though, this is almost certainly against your Universities IT policy and you could be in big trouble if they find out.
As for the comments above, not "any" wireless router will work, you need a wireless router with an Ethernet based WAN port (e.g. cable router). Your University is almost certainly only going to allow a single MAC address to be connected at any one time.
This. I would ask the IT dept firstly if your allowed that.
I would rather go through the hassle of having to connect up than putting my future at risk.
If its for tablets of your phone etc, could you not just keep the laptop hooked up and share the connection?
Why would you need a WAN port? Its connecting to a network, not a modem.
As mentioned you'd need a router with an Ethernet WAN port, so anything sold for cable/fttc use would be suitable.
The odds are that many of your neighbours will have the same plan, so it'll be a mess of routers all fighting for the very limited number of available wireless channels. Depending on what you want to connect it might be worth looking at 5GHz options.
For a single room the TP-Link TL-WR702N is worth considering. Considering their diminutive size they work very well.
You've already been warned, but do check the IT policies, and what sanctions are likely to be imposed. You could find yourself without any Internet access at all.
As said, check the IT policies. I know Sussex allows it, as long as it's configured correctly.
I bought the TP-Link TL-WR841N since it was cheap and allows doing this, as well as giving me LAN ports for my desktop. Although, things happened and I'm living with friends in a flat instead of the campus :p. But I still wanted my devices in it's own network...
