wifi range extender any good?
Permabanned
6 Feb 2010
Barnsley
Something like THIS worth buying just to get a better signal into my little girls room for netflix streaming.
Also how hard are they to set up and are they safe
Honestly, no. It will sort of work, but the truth is that it will only ever be a stopgap solution that frustrates as much as it works.
Powerline adapters are better, a proper cable connection is best.
What would be a good range extender?
Such a thing doesn’t really exist. In descending order of preference you can try the following:
  1. Run Ethernet cables and put wireless access points on the end of them
  2. Introduce a wireless mesh system
  3. Run a pair of powerline adapters, one of which has a wireless access point built in
  4. Buy a range extender
1. And 2. are decent solutions. Most people who know a bit about networking couldn’t bring themselves to recommend 3. or 4.
If you must go for a range extender, buy the cheapest going (they’re all rubbish) and be sure to put it half way between your router and your dead spot and have low expectations.
Thanks @BigT
would something like THIS be any good?
my problem could just be the piece of poo plusnet router i have, i never had this problem with sky and there located in the same place. would it be better to just use a better router
From someone who has tried a couple of "range extenders", I can safely say they are ****. They paper over the cracks of a bad network and you'll still have issues, and resolving them become even more frustrating with an extender in the mix.
Thanks @BigT
One of the best all-in-one Modem/router/AP combo units (from a WiFi viewpoint) is the BT SmartHub. The problem with all these units is that they are legally limited to what power they can transmit and the antennae are generally poo so the reception is also poor.
Can you relocate the router to somewhere central and high up? The ideal is to have just 1 wall or floor between the AP and the target device. It’s remarkably easy to extend the point where the ADSL or VDSL comes into the building.
Make sure it’s not hidden behind the TV and sometimes building a tent out of tinfoil behind the router can also help reflect signals back to the client. Unfortunately WiFi is very difficult to optimise cheaply.
On the contrary I picked up a TP-Link RE350 in November to boost signal to my garage that was a tad on the weak-side and had begun to start dropping out.
Plugged it in, set it up in 5 minutes and haven't needed to touch it since.
I have been using a wifi access point for yrs, as my router is at the one end of the house, So I moved the wifi to the middle of the house with a access point to cover the whole house and I haven't had any problems either.
