Wifi repeater/extender for bt youview box
18 Apr 2013
Hi all,
I was wondering which wifi repeater/extender with a ethernet socket you would recommend for getting a good pictures/stream on a bt youview box. Preferably it would have ac but im not sure how necessary that is. Also cheaper the better. So if you could recommend a budget option as well that would be great.
I know most will say use powerline adaptors but I have tried and its far too unreliable where as i never have issues with wifi on my android box or ps4 as get i get a very strong signal. Also hard wire is far to much work from my router upstairs to my front room hence the need for a wifi extender/repeater with a ethernet socket.
You can pickup Sky On Demand Connectors pretty cheaply.
Designed to add wireless to Ethernet only Sky boxes but should work with any Ethernet equipped device.
Picked up a netgear wifi extender with a ethernet socket that wasnt being used at my mums yesterday plugged it in and connected with wps and it worked flawlessly. I'll take that.
