- 14 Nov 2002
- Under the Hill
I'm having a big problem with our network connection at the minute.
We have a Speedtouch 510 v6 adsl modem and a Netgear MR814 v2 Wifi router.
The problem is this:
Wired connection from modem to router = success
Connect the modem to the router and I can access the modem and it's settings using ip 192.168.1.254, however I cannot browse the internet.
Now the modem's manual is next to useless but I can confirm the following:
The login details are stored on the modem and arew correct.
The router also stores pptp (not ppoe or ppoa) settings and passwords. I have tried putting in the login details there as well as leaving it as the connection does not require a login and neither works. i'm not sure what to try now.
		 So are you saying that the ADSL sync is lost as soon as you plug the Netgear in?  Do you mean that you just can't get out to the Internet or that the router's sync light literally goes off?
