WiFi Security Cameras?
10 Sep 2003
Midlands
I know there are some CCTV experts here... After some recent car vandalism I am in the market for a CCTV system for my house.
I'm looking for something that has one or two cameras, outdoor, wifi and can be hooked up to a PC. There seems to be dozens of cameras offering this on ebay but can anyone recommend anything in particular?
Thanks.
Any reason for WiFi?
You are going to need to power it anyway so a cable run should not be too difficult?
Unless the run back to a switch/router is not possible I say go for a POE unit with an inline power adapter then you only need the single cable. Plus, working with Cat5 is easy!
