Wifi settings on Ipaq 4100
1 Jun 2004
Derby
Evening all,
I've just been given the above pda but i'm a little stuck with the wifi settings that I have to use in order to use my Sky wireless broadband with it. I have looked at the manual but it does not say anything about entering a network key on the connections bit on the pda. It just gives you the option of connecting to a list of available wireless networks. :confused:
Does anyone have any instuctions on how to set the ipaq up with a sky wireless broadband connection or is there a 3rd party software that I need to use?
Thanks in advance
Chaz
A quick update...
I was advised to update my rom from HP's website from 1.0xxx to 1.10xxx. I have done this and updated my wireless lan drivers (also from HP) but now the ipaq isn't picking up any wireless networks. I have tried to install my sky broadband on the ipaq manually but on the "Configure Network Authentication" screen on pda under the section data encryption it only gives you the option of Wep or Disabled. The problem is that I need WPA-PSK.
Anyone know what i'm doing wrong?
