Wifi , setup authorizations?
20 Oct 2002
Oxfordshire / Bucks
Hi
I have a netgear nighthawk wifi 6 router
Is it possible to set up a scenario like this?
When someone tries to connect to your router, it asks for authorization. So I can either accept it, or decline it?
Thanks
Thanks Chris
yeah no thanks, not a business, just a simple home network, that i just wanted to know if someone tried to access it basically
cheers :)
Not familiar with that router but if you wanted something simple you could check the DHCP leases, and block handing out a lease to a specific MAC.
Of course it wouldn't stop someone setting a static IP and connecting or if the device your blocking's MAC changes often.
Maybe something like this? https://www.groovypost.com/howto/mac-filtering-block-devices-wireless-network-asus-routers/
Again what I mention isn't exactly what you describe where you get like a push notification and you can accept/deny.
