WIFI software??
10 Jan 2011
Hello,
I think I might be looking for something that isnt out?
Basically what I want to be able to limit the WIFI usage for certain devices, I know I can log into the router itself and manually turn off stuff but this is a hassle and takes a fairly long time do to, is there no software that'll allow me to what I want do to easily within windows?
If it's a data limit, Windows 10 offers a built in option, under network settings and then selecting properties on the network adapter, there's a "Metered connection" option.
Certain devices on your network, you mean? That all needs to be controlled via your router. Some manufacturers might offer mobile apps that allow quicker access to those settings though.
router is your best bet,
Then somthing
bitdefender home hub thing
or
glasswire can do this on Windows/Android
Fairly sure a lot of routers have parental controls which can block certain devices from internet for X hours in the day
