Very unlikely at this budget. Bluetooth is so overwhelmingly the go to wireless connection for budget speakers, you're only likely to find speakers that can accept WiFi at a much higher price point. Sonos for example.
If you need WiFi rather than Bluetooth, then if you can stretch to more than £50, you could get a Neet WiFi receiver for around £25, then connect that to any speaker of your choosing. Whilst you could spend £25 on the speakers, that isn't going to buy much worth bothering with. Edifier 980T can be had for £50, which are by far the best speakers available for up to that price point.
