- 31 Dec 2021
- UK
I have a detached garage in my garden approx 40 ft from my house which I want to be able to send an internet signal to - nothing extreme, just enough for HD video and music streaming.
Running an Ethernet cable externally isn't an option and due to the wiring to the garage, neither is using a powerline.
What options do I have for WiFi?
I had looked at a mesh system (Deco M4) however to install this I would need to do away with my Archer AX50 router which I'm not keen on doing as it has only recently been purchased.
If I were to get rid of my router and replace with a Deco M4, I wouldn't be getting the full benefit of Mesh as my second node would be just a few metres away from the master, next to the window closest to the garage with my third node then being inside the garage, therefore not adding any value to the rest of the house.
Is there any solution that would allow me to keep my existing router but the. Send a strong WiFi signal to my garage which would be capable of HD video streaming?
