- 17 Jun 2011
Hi all,
I have recently upgraded to virgin gig1 and receiving around 940mb down and 50mb up wired on my pc.
I want to make the most of the connection on my wifi devices and have a few wifi6 devices that can utilise the speeds a wifi 6 router can offer. What I am looking for is a wifi 6 router with a multigig port that will make use of future gig+ speeds. I know the hub4 doesn't support gig+ ports so thats a bottle neck there at modem level but hopefully vm upgrade it.
My current set up is a rt-ac3200 in router mode with the sh4 in modem mode. I then run a 25/30 meter cat 5e (will be replaced) upstairs to another rt-ac3200 router acting as an AP.
Can you please recommend me a router that can handle the 900mbps throughput over wifi? I will probably buy 2 to mirror the set up I have today.
Also heard about wifi6e, maybe thats worth waiting for?
