Wii-360 not inuf connections :( ...
30 Jan 2004
UK
Hi all
need some help with the wii and my HDTV...
i have a Samsung LE40R51B LCD and i also have a 360 but the LCD only has one set of component inputs.
So is there any why i can connect both the Wii and the 360 and still get a good picture from the wii. And will i still get 480p?
This has put me at a right dylema i mean i could just unplug it every time but surley there must be another option. Can you not get something that gives you more component outputs like a breakout box or something?
Thanks for any help
XD-3
Buy the microsoft vga cable for the 360 and connect it to the tv using the vga port on it.
Leaves the component input free for the wii
what is picture quality like through VGA compared to Component ?
XD-3
Could i also use one of these...
Joytech Control Center 540C
Features
Proprietary Xbox 360™ connection carries all console video and audio through one simple lead
4 HDTV ready Component Video inputs, 5 Composite Video and Stereo Audio inputs, 4
Built in 5 port 10/100 Ethernet Lan Hub provides reliable connection to PC, Xbox Live® and
Customizable Backlit LCD Display allows user to name individual Inputs for simple navigation
Remote control included for effortless switching between AV Equipment
Component and Composite cables included
I wouldn't bother with any of that, just get the MS VGA cable for your 360. There's not much difference in the quality, VGA may be a little sharper compared to more vibrant colours over component.
Personally I prefer VGA.
Features
looks like VGA then :) thanks for all the replys guys will be a lot cheaper then getting the control center anyways.
I might get that at another time when there is a need for it.
XD-3
