Wii Cables
18 Oct 2002
Sunderland
Ok so the Wii comes with a composite cable, and you can buy RGB and component cables.
My TV is non HD, I use the 360 through its VGA port so whats the best solution? RGB? Is that better than the standard cable? Or should I try to get some sort of VGA convertor, and a VGA splitter? Will I even see a difference between that and RGB?
