Wii charger
3 Feb 2003
Shropshire
Whats the best wii remote charger no matter the price? Is there an official one?
There is hundreds around on the net but i have already gone through two and you have no way of telling which are good or not. :(
Any recommends?
I found that the nyko charger is really good, doesn't over charge the batteries and batts last a long time.
I know the one that has space for 2 wii-motes not sure if they do one for 4.
ive got one of these
"4Gamers-Remote-Charging-Stand-Wii"
it replaces your existing stand, but has slots for 2 wii motes at the side. Insert some rechargable AAA batteries and you're good to go.
It doesnt include batteries with it, but you can get
Fameart Ni-Mh Rechargeable AAA - 1000 mAh - 4 Pack
for £3.49.
Job done.
for £3.49.
Job done.
That's what we have for the one at work, seems OK.
for £3.49.
Job done.
If only they had the room. Their wii has to lie flat.
How does the straps go onto the charger with tis one? Also where does it power from?
It's mains powered, there is just enough room to put the them in and have the straps come out on the sides of the charger. and you can just push them behind so they don't show.
