Is there anyway to turn off the Wii completely, or can you only put it in standby? Also, is it normal for the power pack to be so noisy? Just worries me a bit when I have the TV off and I can hear the power pack buzzing away
RuMp3l4$k1n said:My power pack doesn't buzz in standby or when the Wii is on so check your cables are all nice and snugly plugged in.
If you don't want the Wii in 24/7 mode(orange power light) hold the power button for a few seconds longer to turn it off, the light will go red instead of orange.
Any further than that you just have to switch off at the wall.
It should be a pale colour, similar to straw and its odour not too pungent.Wii concerns
