Wii factory reset
6 Feb 2003
London
Is there any way to do this? I accidently put it on the wrong screen settings in the options (60hz instead of 50hz) and now theres no picture for me to change it back again..
Hit it with a hammer - it should do the trick. I mean, none that I'm aware of. Unfortunately, due to the pointery'ness of the Wii's dashboard, simply running through a series of keystrokes blindly isn't possible either.
I guess you'll have to find someone with a modern TV, presumably. You can use mine!
