Wii Hdmi adapter
11 Jul 2003
Telford//west mids
Found my old wii in the loft so I'm going to gift it to my grandson, but my TV doesn't have the cabled connection it needs it only has Hdmi,can anyone recommend a good one, I've looked around and some come with bad reviews of it not working, so I would like to know if there are fully working ones out there.
I have used one of the cheap white generic ones and it was ok.
Don't think there is much quality control with them so some work some don't.
Get it from somewhere with easy returns
The 'wii2hdmi' white ones on ebay or amazon are what £8 iirc last time I bought mine and work fine, if it doesn't ebay and amazon let you return them at the sellers expense, so no worries there. Make sure you enable 480p in the settings so it's smoother and progressive vs the 580i interlaced preset ;)
