Wii HDMIKey
2 Apr 2007
North Shields
HDMiKey is a sleek and stylish product that allows all Wii owners to hook up their consoles to any display with HDMI or DVI interface. It plugs directly into the Wii and doesnt require any big and bulky power supply. It also has dual digital and analog audio output for connecting the Wii to state of the art sound systems. For displays without upscaling it also offer internal upscaling up to 1080p. HDMiKey firmware is fully updatable due to an unique update system. Built with only the highest quality components, gold plated connectors on both sides and a solid 4 layer PCB this product is a must have for Wii gamers!
http://hdmikey.com/
- So what do you guys think? Will make a difference to picture quality?
Here is a video to a similar product.
You can't just pull quality out of the ether.
I doubt it can be any better than existing component/VGA/DVI connections.
Upscaling is pretty much irrelevant as the TV will upscale the input to the native resolution of the TV anyway.
