Wii port?
From the Wii website
Allowing TCP and UDP Traffic
The Wii console may require unrestricted access to several sites across various ports and protocols to function correctly. These addresses and ports vary, and may change in the future without notice. Many software firewalls restrict outbound access. Only if your firewall blocks outbound traffic do you need to enable this traffic:
TCP:
Allow traffic to all destinations on ports: 28910, 29900, 29901, 29920, 80, and 443
UDP:
Allow all traffic to all destinations. (Necessary for peer-to-peer connections and game play). Our Network Test tool can be used from a computer behind your firewall to test if outbound UDP is allowed.
Please note that by allowing the traffic to the destinations listed above, you are essentially removing a significant amount of firewall protection for your network. While Nintendo provides this information for our consumers' use, it is up to each consumer to determine what security needs they have for their own networks, and to decide how best to configure their network settings to meet those needs.
