Wii Question : spare sensor bar?
18 Apr 2003
Peterborough
are these going to be sold anywhere? ive stuck my one using the sticky bits to my TV, now when i go around my mates over xmas he wants me to bring the Wii.... but i cba to yank the bar off and mess up said sticky bits
I don't think you can get spares for it yet however you do get spare sticky pads in the box.
You also get a clear plastic stand that the sensor bar clips to if you do not want to stick it on.
Really? I guess I should check my box.. I've just been using blu-tack to stick the bar above my screen as I knew my Wii would be going walkies a lot. There are supposed to be third party wireless sensor bars in the making right now which would've been nice out of the box.
The third party one I've seen is shocking. It's a bit of trunking, with a battery, switch and 4 IR LEDs. Pop into Makro and make your own lol.
