16 Sep 2007 at 21:53 #1 ryu ryu Associate Joined 25 Oct 2002 Posts 1,167 hi, just bought a wii, and was just wondering if it is compatible with basically all the standard sd cards available? thanks
16 Sep 2007 at 22:04 #2 Drukk Drukk Associate Joined 5 Feb 2006 Posts 1,162 I use a sandisk ultra II 2gb card and it works fine.
16 Sep 2007 at 22:05 #3 NokkonWud NokkonWud Caporegime Joined 1 Oct 2004 Posts 26,315 Location Redcar I believe it's anything up to 2gb.
17 Sep 2007 at 00:14 #4 GarethDW GarethDW Soldato Joined 22 Jun 2006 Posts 2,971 Location Swindon Not had any issues.... have used branded and unbranded ones. Only ones I've not used are the official Nintendo ones, because they're a rip-off.
17 Sep 2007 at 00:48 #5 Kamakazie! Kamakazie! Associate Joined 12 Jan 2003 Posts 2,092 pretty much anything that is not a sd-hc card will work. A lot of site show compatibility lists anyway so you should be fine.
17 Sep 2007 at 11:20 #6 Gigi Gigi Associate Joined 24 Aug 2004 Posts 2,260 Location Edinburgh Just wait until they update the firmware to allow for USB Hard Drives to be used as storage
