Its been a long time coming but the parts are starting to arrive. Unfortunately I have a massive travel schedule coming up for work over April so this project is going to be a slow burner.
I'll record my progress as I go along with photo's and write down my experiences of my first watercooling project as I go along. I am expecting this to a quite a learning curve, but none the less I am still aiming for a good quality end job.
Outline of the project:
Watercool a 2500K + MSI 7950 inside a cm690ii with zero mods to the case using a total of 600mm worth of rad !
Now on to the kit. FOr the fittings I got lazy and couldn't be bothered photographing each one so I just stuck a few together so you can see what I am going to be using.
Koolance Compression Fittings
Bitspower 45° Rotary compressions
Bitspower 'T' fitting for the drain line
Bitspower Tap for the drain
GPU Block and Backplate - Heatkiller 79X0
CPU Block - Koolance 380
Koolance Resevoir with dual Alphacool D5 varios already installed
Pumps will be working in serial, but I won't be using the serial connector for the res. The loop will run like this
so loop would be Res > P1 OUT > CPU > RAD > RAD > P2 IN > P2 OUT > GFX > RAD > P1 IN
120mm self adhesive radiator gaskets
UV LED ligthing for res and case
MSI 7950 OC v2 and more Corsair RAM (already installed in the case a few weeks ago
Kit Still to come:
Hardware Labs Black ICE Radiator GTX-Lite 240
XSPC RS240 Radiator
Hardware Labs Black ICE Radiator GTS-Lite
Mayhems Pastel - UV White Coolant
Arctic Cooling MX-4 Thermal Compound
Lamptron FC2
Sythe GT 1850 fans x 6
Tubing
A few more 1/2" ID - 5/8" OD compression fittings
Kit Still to come:
XSPC RS240 Radiator
Lamptron FC2
Tubing
