Will 5770 go in GA-965P-DS3 (rev. 1.0)
24 Aug 2006
As tittle really, Looking at getting a 5770 to replace my old card but concerned if i have the correct PCIE slot as i see PCIE 2 mentioned on the 5770 page but not on the mobo homepage.
Thx sk1n.
When i checked my existing sytem with TechPowerUp it shows my PCI-E @ 16x, is this a v1 or v2 of PCI-E spec?
Is there any physical difference in the slot??
Sk1n
