Will 680 SLI fit?
6 Dec 2008
I have 2x 480 SLI atm but they fit very tightly in atm. I think maybe if the 680 gtx is bigger it wont fit??
My case is the Corsair Obsidian 800D [the full tower one] I cant remember my motherboard, anyone know how I can find name of it?
Thanks!
Oh, well if that's the case than thats good news ^^ You know how I can find out for sure if size is right? I cant find any sizes for GPUS
When i meant tight fit, i meant, they are very close together in the motherboard. There isnt much of a gap between the 2 cards if that makes sense?
The Corsair Obsidian 800D can fit 2 cards easily.
Also, if it's the motherboard spacing you are talking about then it will be fine, they are both only 2 slots. The bottom and top cards are quite often almost touching when running SLI with any dual slot card.
Thats what I meant "Motherboard Spacing" haha :P Thanks a lot man!
Ah should have realized thats what you meant, I run mine in slot 1&3 so mine are spaced out.....you will be fine with the gtx680's as they run a lot cooler than a 480
