- 29 Jun 2005
- London
Currently an 8800 won't fit into my case, not that I can afford one anyway, but I'm curious if anyone knows whether the cards will be brought down to the size of DX9 cards eventually?
What model is your case...mcwildcard said:Currently an 8800 won't fit into my case, not that I can afford one anyway, but I'm curious if anyone knows whether the cards will be brought down to the size of DX9 cards eventually?
are there any dates for the 320mb version launch yet ?and the new 320mb GTS which is coming now may be a bit shorter
pegasus1 said:So much for advances in technology, PSU's getting bigger, CPU coolers getting bigger, Gfx cards getting bigger, case cooling getting bigger. I reckon the sucessor to Blu-Ray will be use discs the size of a vinyl LP.
So you ticked the 'No sense of humour' button when you joined the forums.Deiwos said:So make a fortune and design smaller models then![]()
Didn't realise it was only the GTX that was larger!LoadsaMoney said:They are the same size as Dx9 cards, its only the 8800 GTX which is longer, the GTS is the same length as ATi's x1k range (x1800's/x1900's/x1950's), and the new 320mb GTS which is coming now may be a bit shorter as it has less memory chips, also the 8600's etc... the low/mid range cards from Nvidia should also be shorter.![]()
I have a Silentium T1 Pro: http://www.overclockers.co.uk/showproduct.php?prodid=CA-002-ARBFG_9000 said:What model is your case...![]()
lmao, what are you on?pegasus1 said:So you ticked the 'No sense of humour' button when you joined the forums.
Smaller models would need smaller cat walks........Ha Ha Ha ha ha ha
