will a 1950pro fit in a sugo
yes :)
Friend has one, he also managed to fit an 88gts in, and the gtx fits with a bit of modding...
ah cheers dont suppose u could get any pics
also did he have to remove is hard drive bay and put a hard drive in the 5.25 instead
cheers cant afford to waste money
see i can either get a 1950pro for 70 quid or a 7900gs for 56
need one to replace my 7600gt which has to go in kids comp
U can fit any graphics card in a sugo & only the GTX requires any kind of modding to fit.
Pics of a 1900xtx & 8800gts (both bigger than the 1950pro & 7900gs)
Ive got an X1900xtx in my Sugo 01 Evolution. as said above any normal sized card should fit in, and longer cards will if you remove the Hdd tray
