- 9 Nov 2014
Hi,
I recently purchased an EK KIT 360P for my CPU and am chuffed with it.
What I'd like to do next is add a GPU to the loop. I don't really have enough space in my PC for another radiator so I was wondering if the single 360mm radiator that came with the kit will be sufficient to cool both components.
I'd imagine my CPU will be cooler as the rad is set up as an exhaust at the moment and has all the hot air from the GPU blowing through it.
What do you guys think?
Also, I can get a full Bitspower waterblock for the 980 Ti Lightning I have for 189 Euros. Is this too much as I realise it's an end of life product? It's just cheaper than buying a new card and a waterblock for the new card! Or would you guys recommend hanging on for a bit and grabbing a 1080 Ti and adding that to the loop?
