Will a 5970 fit into a fractal r3?
27 Sep 2009
Help with the above please. a friend is selling one for £120. im thinking of buying it off him but don't know if it will fit in my case. he doesn't live close so cant exactly borrow it of him
ignore the specs in sig. dont have that gpu anymore
I don't think it will fit. The Fractal Designs Define R3 supports graphics cards up to 290mm. A reference HD 5970 is 309mm long.
However, if you know the exact model you're getting it might be shorter if it has a custom PCB.
selling an R3 seccond hand for £120?
friend?
well.. hes a friend im sure he will let you try it in there first... but just FYI they are only £80 new from ocuk
i have found out this Fractal = 290mm of space for GPU's 5970 = 309mm in length. but someone said above that some 5970 might be shorter than others. any ideas which are the shorter ones
thanks
thanks. talking to my mate again he has overclock them and messed around with them so decided against that one. pick up a new dell oem one for £220 with 1 year rtb warrenty. there is a handle type this at the back but it can be removed.
thanks for the video
