Will a Coolermaster Cosmos Pure 1000 fit a triple radiator in roof without modding?
11 Oct 2006
Reigate
As per title really lads!
I know the Cosmos S can (as I built a rig with it for a mate) however, another friend of mine wants me to build him a gaming computer and we are desperately trying to search for a case that can house a decent internal loop (ideally with space for a triple in the top!).
Cheers!
Don't think so. Spec says top cooling is 2x120 mm fans, not 3x120mm.
For £150 (presuming that's the budget for the case), you can get some absolutely incredible cases though.
Shinobi XL, Xigmatek Elysium, HAF X, Switch 810 all have massive capability for watercooling. 650D also has a reasonable amount of capability (think it's a slim 240 in the top, with a 200 in the front).
kd
Hey man
Thanks for the suggestions - it's good to know I was thinking in the right ballpark as I had it down to those as well (obviously plus the Cosmos).
I think the Cosmos II is too big for this project.
My mate likes the look of the HAF X but I'm tempted to sway him towards a Shinobi XL as they receive really good press atm.
To be honest, whilst I think the XL will be a solid case, the reviewers haven't quite finished reviewing it yet. Personally, that will be what I'd spend my money on.
The NZXT Switch 810, is an absolutely incredible case though if you can get on with it. I must admit to not liking the plasticy-ness of the whole thing.
If he does choose a HAF X, there's nothing wrong with it. It is still an absolutely stunning case, and will take pretty much everything you can throw at it. Although thinking about it, that too may need a bit of modding to have the mounts for 3x120.
kd
