Will a good Scythe fit in here.
9 Jan 2005
Stoke-On-Trent
I'm getting extremely low idle temps but while running prime the temps can hit 67C on my Q6600 @ 3.2Ghz with the retail fan. So I'm after the most uber aircooler I can possibly fit in my Media Centre.
scyther probs wont fit.
those temps are good for a retail cooler btw. I only get a bit less than that with my tuniq tower and a quad at 3ghz, because of airflow issues, so if you dont have great airflow i'd leave it tbh.
those are nice temps on the stock heatsink, unless you plan to clock it higher no need to swap off the stock fan... I dout anything that PC will do will load the CPU like Prime does
