Will a GTX 560 TI be compatible with this psu?
No problem and welcome to the forum :)
Thanks aha. Btw, would this be a good gaming build for £600?
Intel core i5-2500k
> 4GB DDR3 Kingston 1333 (2 x 2GB),
> 1155 Gigabyte GA-H61M-S2P-B3 - H61Mchipset - 2 x DDR3 1333 - Gig Lan - SATA 2 - USB2,
> 500GB SATA Hard Drive SATA 2,
> No Secondary Hard Drive,
> DVD+/- RW - 22X Samsung SATA,
> 1024MB GTX 560 Ti PCI Express Nvidia DDR DVI DX11,
> CiT 1011B Midi Black Case with 500W PSU,
> OCZ 600W PSU - STEALTH XTREAM 2,
Intel core i5-2500k
You may want someone else to answer, I dont do these spec me threads, I haven't got enough time to keep updated with the prices and stuff. But it looks an alright build. Maybe better RAM 1600MHz?
Make sure you throw out that PSU that comes with that case aswell. Ew.
As your using the H61 chipset on the motherboard you probably won't be able to over clock the cpu.
Thanks, and aha ofc i will :)
Yep that's fine with me, knowing me i'll end up ***** my cpu up attempting an oc anyway
