will a Gtx570 fit
14 Jan 2011
Aylesbury
I already have a thread running in the hardware link but I am just trying to cover all bases.
Im building my first full pc soon , I am going to buy a Coolermaster CM-690 II Advanced Dominator Case.
Will a gtx570 fit into the case ok, looking to go SLi cards inthe future.
Will a Akasa AK-CCX-4002HP Venom CPU Cooler fit ok, may go the H50 or H70 route instead if funds allow, will they fit.
thanks for ant advice.
Yeah, they should all fit, if the graphics card doesn't then it's easy to take out the hard drive cage and then just mount the hard drive in a 5.25" bay.
After further investigation. it looks like there is 11.96" between the hdd cages and the back of the pc, its quite tight but I believe the GTX570 series will fit in with out any mods to the case.
